Bearing w/ hub... still need a press?
Old Apr 15, 2007 | 01:24 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default Bearing w/ hub... still need a press?
If I purchased this
http://cgi.ebay.com/ebaymotors/1999-...spagenameZWD1V
Hub w/ bearing, does it still need a press to replace the bearing. Does it make the job easier? Would I save money to purchase this instead of just the bearing?
Old Apr 15, 2007 | 01:45 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
ick tech :barf:
I can't say for sure because it has been a while but I don't think you would need a bearing press. You will need a BFH and a good swing (or 20) but not a bearing press.
Old Apr 15, 2007 | 02:02 PM
fathergoat's Avatar
fathergoat
:3
it reads to me like the bearing is already pressed in, but I don't have an accord so :dunno: if your going to use a BFH to put a bearing in at least use a block of wood to cushion it. On small parts I'd rather just take the part to a garage and have it pressed in properly rather than risk damaging a bearing.
Old Apr 15, 2007 | 02:04 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
no
but for fuck's sake Honda OEM is only like $10 more.
Old Apr 15, 2007 | 10:36 PM
Kestrel's Avatar
Kestrel
Push to shock!
Bearing press is the best practice. If you do pound it in with a hammer, do make an effort to try to hammer the race in evenly, otherwise you may develop spots where the bearing sticks.
Old Apr 15, 2007 | 10:43 PM
S2Kev's Avatar
S2Kev
No need for a press. Should already be pressed on for you. I'm assuming this is for the rear?
Old Apr 15, 2007 | 10:46 PM
Civic2Scooby's Avatar
Civic2Scooby
if its an assembled hub than no press is needed....but for god sakes go OEM honda...
Old Apr 16, 2007 | 04:26 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
that bearing wont last long, i have seen what happens when people use aftermarket bearings. For the rear you dont need a press, u just need a 32mm socket and then usally it slide off.
Old Apr 16, 2007 | 04:45 AM
it's an assembled hub, just swap it out.
Old Apr 16, 2007 | 01:21 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
I went to they mechanic, they said $75 to install the bearing, so Imma just get the HONDA bearing $51 plus shipping. BUT should I get the CIRCLIP also (see part # 21)
http://www.hondaautomotiveparts.com/...)&vinsrch=null
