Need help: 2003 Accord LX ABS light on
Old Feb 16, 2007 | 10:29 PM
va22030's Avatar
va22030
Default Need help: 2003 Accord LX ABS light on
When I drove at local road on a snow day, the ABS light suddenly lighted on. I turned off the car and then turned it on before a red light. The ABS light was still on. When I turned on the car next morning, the ABS light was off. However, after I drove 10 feet on snow, the ABS light was on. From then, the ABS light is always on when I drive the car. I need your idea and experience where is the problem.
Thanks.
Old Feb 17, 2007 | 12:20 PM
Fuse's Avatar
Fuse
You will have to get the code pulled at a shop.Brake switch failure or wheel speed senser are the molst comen failures.
If you want to read the code your self let me know i have found a trick on obd2 to blink all system codes.I will need to know if it is a v6 or 4 banger.
Old Feb 17, 2007 | 07:25 PM
va22030's Avatar
va22030
Thank you very much for your response. It is V4. If you can tell me how to get the code, it is super.
Thanks a lot.
Old Feb 18, 2007 | 12:00 PM
Fuse's Avatar
Fuse
a v4 never herd of it.Is it a g23z6.All right give me a min.
Old Feb 18, 2007 | 12:12 PM
Fuse's Avatar
Fuse
Ok all systems have an old scs wire that all go to pin 9 of the data link connector aka dlc.If you use the view attached ,this is looking at the front side of the dlc, jump pin 9(the circled one)to ground ant turn the key on.It will blink any dtc in any system(abs,ecm,tcm).
Now to count the blinks if you have 3 long blinks and 2 short blinks your code is a 32 get it.
After reading the code un jump the dlc to ground and get back with me on the code.
Ps.only jump pin 9 any other will blow fuses or control units.
