01 Accord, tcs light on, misfiring, code 31
Old Jan 14, 2007 | 04:32 PM
motopsyko32's Avatar
motopsyko32
Default 01 Accord, tcs light on, misfiring, code 31
Today car was running fine, took a hard right turn from a dead stop (upset at traffic) and tcs light came on, car started misfiring and wouldnt go passed 3500 rpm (limp mode ecu).
Pulled over and disconnected the battery for 5 minutes to reset the dtc and once reset, problem still exists...
TCS flashes code 31 and engine badly misfiring...
wont shift unless i let off the gas pedal.
Old Jan 14, 2007 | 05:25 PM
FallenAngelHIM's Avatar
FallenAngelHIM
sounds like your tranny...
Old Jan 15, 2007 | 10:24 AM
motopsyko32
found the problem is the CKT Sensor....
Special order part:
147-7037
CRANKSHAFT
POSITION SENSOR
Honda (37501-P8A-A01)
Acura ....................1998-1999
Honda...................1998-2002
seems like the bracket that holds the sensor by the timing belt vibrated loose and the timing belt messed up the sensor...
