MY 98 accord v6 's check engine light is on!!
It has 90k miles and its an EX.
the light went on yesterday after I refilled gas.
I am the original owner what should I do step by step?
I am not very good at fixing cars.
also the maint reiqured light flashes too even though i changed oil not 2k miles ago!!!!
Your maintainance lights will flash/go on regardless if any maintainance was done or not. It's just a reminder and unless it is reset it will continue to flash/stay on.
:werd:
if it happened right after filling gas... then the cap is probably loose.
heres how to reset the maint light.... https://www.honda-acura.net/forums/s...ad.php?t=47758
Sounds like you have really bad luck man......what makes you think the timing belt broke???
damn,.....how are you sure your timing belt is broken? Do you see it hanging under the car? Maybe you meant power steering belt?
