RPMs at idle
Old Dec 24, 2006 | 07:23 PM
b-bomb's Avatar
b-bomb
Default RPMs at idle
Today while I was driving I realized when I came to a stop that my rpm was jumping between 1k and 1.4k without applying any gas. It drove normally and when I got it home I messed with it some and after revving it a bit it stopped it temporarily. I was trying to find out if something was stuck open or something. This is for my 91 accord 5spd.
Thanks in advance.
Old Dec 24, 2006 | 07:49 PM
Misa's Avatar
Misa
Pic Whore
its your IACV / FITV
do a search.
Old Dec 24, 2006 | 08:05 PM
b-bomb's Avatar
b-bomb
do a search.
Thanks
Old Dec 24, 2006 | 10:34 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
I got a similar problem my rpm goes from 1k down to 700 and the car would shake, do you think it the same thing?
Old Dec 25, 2006 | 07:13 AM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
also might be the EGR valve....a bad egr valve will cause a rough idle at stops and sometimes a "sluggish" feeling at low speeds but usually wont effect highway speeds
Old Dec 25, 2006 | 10:24 AM
b-bomb's Avatar
b-bomb
Default problem fixed
it was a hose that had come loose.
Old Dec 25, 2006 | 10:40 AM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
so it was a vacuum leak...easy fix's are the best fix's
