Changing Transmission Oil
Old Jan 6, 2007 | 06:38 PM
Jon02Accord's Avatar
Jon02Accord
is there a screen to clean?
Old Jan 8, 2007 | 06:48 PM
tpowers's Avatar
tpowers
I sure Hope It Isn't F*ked Up. My Wife Loves Her Car. She Is Hoping It gets better or last a little longer,so she can get the funds for putting it in the shop. I Only Changed the Tranny Fluid 2 times w/3quarts, better but not 100% Cleaned Shifts Cylinoid Screens (Dirty). Wish Me Luck
Old Jan 9, 2007 | 06:49 AM
JimBlake's Avatar
JimBlake
The torque converter doesn't drain, so when you drain/fill you only get about 1/3 of the fluid. If it's real dirty, you may need to do 4 or 5 or more drain/fill cycles. Drive around to mix fluid inbetween. There's no filter or screen that you can change (unless you dismantle the tranny).
Still, no guarantees. There must be a reason why Honda says NOT to 'flush' their automatic trannys. I think partly it's because the flushing machine uses some kind of solvent - not pure ATF.
Old Jan 9, 2007 | 07:57 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
An external tansmission cooler may help prolong the life of your tranny, I just hope it hasn't gotten too far.
Old Jan 9, 2007 | 08:00 AM
flyromeo3's Avatar
flyromeo3
Jim,...have you ever cleaned the linear solenoid? Its under the battery tray against the tranny. Hard to see. You gotta get in there to find it.
its this one circled in red
Old Jan 9, 2007 | 09:28 AM
OptimusPrimeSr's Avatar
OptimusPrimeSr
how did you do this and what did you use? Did you remove the tops like this...
Old Jan 9, 2007 | 10:03 AM
flyromeo3's Avatar
flyromeo3
woah....i've never seen it dismantled like that. Theres a screen between the solenoid and housing which where the fluid builds up.
I think the problems with the transmissions is with the hydraulic system.
Someone told me that replacing the solenoid will fix it temporarily but that it may appear again.
I know for the 5th gen accords developed a tranny problem and the fix was to replace the solenoid.
Old Jan 9, 2007 | 05:43 PM
tpowers's Avatar
tpowers
Its not my car, its the wife's,Her pride and joy and first car she ever brought so I have empathy for my wife. I own a 99 Chrysler Sebring and am into car audio and SPL, guys. Well thanks for showing me the pics,but the tranny went out anyways last night, Thank God Before we made the Trip to the CES show in Vegas. We will replace the tranny cause the car had no other problems. I just f*ked up and took it to Jiffy Lube and didn't listen to people when they told me to use only Honda Products. I decided to get on this forum cause she didn't want to and look like a stupid female and get eaten up by you guys. We Live And We Learn.
Old Jan 10, 2007 | 06:19 AM
JimBlake's Avatar
JimBlake
I've cleaned other similar solenoids, but haven't had troubles with the '98 auto tranny. (yet?) All my other cars are manual trannys.
Old Jan 12, 2007 | 11:56 AM
tpowers's Avatar
tpowers
Damn, I didn't think it would be so hard to find a replacement tranny for the car. ANY LEADS??? I'm In Southern California.
