god awful noise
Old Nov 27, 2006 | 08:59 AM
starky34's Avatar
starky34
94 Accord Lx 5-speed
Default god awful noise
Ok so this is my problem. My 94 lx has a noise coming from somewhere while I am driving. I don't know where it exactly is coming from but I do know that is usually happens while I am in gear and not on the gas.
Ok let me give an example as that was kind of hard to understand. Let's say that I am driving and there is a light ahead so i get off of the gas while still in gear and apply the brake, there will then be this awful metal noise. It's not exactly a grinding noise, as if i were to be grinding gears, but it definetly sounds metal on metal. I thought originally that it was my cat rattleing but that was not the case because I had my cat replaced already, not the heat shield either because I checked that already. So that about sums it up any help would be great.
Old Nov 27, 2006 | 12:54 PM
mycb7com's Avatar
mycb7com
Theres a metal plate down under the tranny, that covers the flywheel. Is it that?
Old Nov 27, 2006 | 01:19 PM
scotttharobot's Avatar
scotttharobot
beer here
brakes?
alternator?
Old Nov 27, 2006 | 01:21 PM
starky34's Avatar
starky34
no i think that i found out what it was, pretty sure that it's exhaust after cat that may have a hole in it. It got worse and worse as the day went on so i checked under the car as i reved it and it sounds like it was exhaust behind the cat.
