5th gen Accord Rpm problem?!?
Old Nov 24, 2006 | 05:57 AM
JdmExR21's Avatar
JdmExR21
07 Accord Coupe
Default 5th gen Accord Rpm problem?!?
Does anyone have a problem/solution for a 95 ex that only revs out to 4500 rpms???!!?? (auto tranny) It driving me nut and it seems like no one has a solution to it. Even the Honda techs were confused
Old Nov 24, 2006 | 08:10 PM
Fuse's Avatar
Fuse
Engine swap?I have had an engine with the timing belt off a tooth.Check you ignition timing to.Any codes?
Old Nov 24, 2006 | 09:10 PM
AJ²06's Avatar
AJ²06
As in it shifts at 4500 and never goes past it?
Old Nov 25, 2006 | 04:41 AM
JdmExR21's Avatar
JdmExR21
07 Accord Coupe
it shifts about 4500 at full throttle and shifts. Hits rev limiter just before 5 grand when manually shifting
Old Nov 25, 2006 | 07:37 PM
Fuse's Avatar
Fuse
so what will it rev in park.No codes at all?
Old Nov 27, 2006 | 04:24 AM
JdmExR21's Avatar
JdmExR21
07 Accord Coupe
It has the stock 2.2 vtec in it. Bought the car with 78000 miles. I don't know if the timing belt was ever done on it though. The only thing i can think of is that maybe the timing belt was changed and the timing is off a tooth. When the car is in park it will rev out to 4750 rmps. Also when shifting manuelly it will hit the limiter at 4750. The car also feels a little sluggish...???? No Codes...
Old Nov 27, 2006 | 06:37 PM
Fuse's Avatar
Fuse
4750 sounds rite.4500 sounds low.Let me talk to a tech that owned one i think the m/t will rev to 6.Or i will test drive one.Give me a day or two.
You could check you timing.Use the picks.You will have to take the top timing cover off and use the white mark on the crank pulley.All lines should line up.
Old Nov 30, 2006 | 04:40 AM
JdmExR21's Avatar
JdmExR21
07 Accord Coupe
thanks i appreciate it
