odometer problems...
Old Nov 23, 2006 | 09:16 AM
R_Squared's Avatar
R_Squared
LEVEL UP
Default odometer problems...
My '94 Accord EX has been having an issue with the odometer and trip odometer lately. Sometimes I'll notice that they'll stick and aren't rolling over, then 10 minutes later they'll be working again. The speedo and tach always work fine however. I had a similar problem with my old '94 Accord LX but that affected the speedo, tach, and odometers...Any ideas?
Old Nov 23, 2006 | 08:01 PM
Fuse's Avatar
Fuse
Read the news first.
Old Nov 24, 2006 | 05:27 AM
R_Squared's Avatar
R_Squared
LEVEL UP
hey, thanks for the info. i do recall the odometer being stuff at a mileage ending in 199. I've only had the car for about 4500 miles or so. How often does the maintenance reminder light come on, and is it very bright? I don't recall ever seeing it turn on. Thanks.
Old Nov 24, 2006 | 03:36 PM
Fuse's Avatar
Fuse
sorry disregard the tack info my eyes were hurting.The maintenance minder comes on every 3 grand.Its a little box next to the key insert its green if you reset it and red if you need an oil change.No it is not bright at all no lights under it.
Old Nov 25, 2006 | 04:01 AM
R_Squared's Avatar
R_Squared
LEVEL UP
i saw that it was lit up green and couldn't figure out why it was still on after i had reset it with the key. but i guess it's always green then unless it changes to red.
