help changing my steering wheel
Old Nov 2, 2006 | 12:07 PM
accordlover's Avatar
accordlover
Default help changing my steering wheel
i need help changing my steering wheel on my 99 honda accord cpe, what about the airbag? and what adapter should i buy i have a marine steering wheel off a 99 four winds(boat), or should i just buy a new wheel?
Old Nov 2, 2006 | 02:10 PM
Misa's Avatar
Misa
Pic Whore
uhh... removing the airbag is illegal in most states... you wont pass inspection.
Old Nov 2, 2006 | 04:01 PM
Fuse's Avatar
Fuse
i would get a aftermarket wheel that will just slide on(a boat???????) you can remove the 2 torks bolts on the side on the wheel and the air bag connector under a little plate bottom of the wheel to remove the air bag and the center bolt under the bag and hit the wheel hard on each side a time or 2 and it will slide off.you might have to ditch c.c. if you have it and yes some states have a safety inspection i don't know much about them hear in co we don't care.
Old Nov 3, 2006 | 05:25 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Buy a TL-S Wheel:yay:
Old Nov 3, 2006 | 03:53 PM
Fuse's Avatar
Fuse
o unplug your battery when messing with air bags(hope i didn't post this 2 late)
Old Nov 5, 2006 | 11:19 PM
accordlover
the sterring wheel i have has 6 bolt holes i have been told that it is the same as the momo wheels, is that true , and if so where can i find a very very cheap momo wheel!
Old Nov 6, 2006 | 06:06 AM
totalimmortal
MalleusMaleficarum
What's wrong with your current streering wheel??
Old Nov 6, 2006 | 06:31 PM
Fuse's Avatar
Fuse
e bay used? momo is a but pricey you have to spend the money to get the look you want.The whell is held on by on 17mm bolt i can get the honda step by step removal if you want.
Old Nov 11, 2006 | 07:14 AM
accordlover
Default yes that would be a great help
i found a couple of cheaper steering wheels on ebay, but i really want one that has the buttons on it.but whenever you can give me the step by step instuctions thanks again
Old Nov 11, 2006 | 07:16 AM
Misa's Avatar
Misa
Pic Whore
you have to be more specific on what you trying to do so we can help you.
by buttons, do you mean cruise control, or audio controls?
