Maintenance Required Indicator flashing
Old Oct 14, 2006 | 11:33 AM
Fuse's Avatar
Fuse
Originally Posted by 98CoupeV6
Negative, Jim. J-series engines use hydraulic roller finger followers and never need adjustment.
i thot is was a k24 thows are ajustable
Old Oct 19, 2006 | 09:16 PM
JimBlake's Avatar
JimBlake
2001 4-cyl; that would be an F23 just like I have. Valve clearance = valve lash; same thing but I don't know where the word 'lash' comes from.
- Do this with the engine completely cold.
- Remove the valve cover.
- Spin the engine (only forwards) until each cylinder comes to TDC on it's compression stroke. This is when both valves for that cylinder are completely closed.
- The adjuster is a small threaded "bolt"-like thing on each rocker arm. You check the clearance with a feeler gauge between the valve stem & this adjuster. If it needs adjusting, there's a jam nut to release so you can turn the adjuster.
- I don't know what the clearances should be. Probably listed on the emmissions sticker under the hood, but you ought to get yourself a repair manual.
- Turn the engine (forward only) to do the next cylinder.
- Age & heat can make the valve-cover gasket hard; it may not re-seal. Get a new gasket if you want.
- Don't over-tighten the valve-cover bolts. They can break...
Old Oct 20, 2006 | 04:18 PM
Fuse's Avatar
Fuse
your rite i that is was the next gen accord but that would be an 03 some time i get confused.
