umm startup problem
Old Aug 12, 2006 | 12:30 AM
qazxswed345's Avatar
qazxswed345
Default umm startup problem
ok so i have an 87 accord... and when i start it it starts fine but whenever i rev it a little to take it off high idle the rps drop so much it sometimes dies... and if it doesnt die it gets very close and then sometimes at red lights the idle goes up then drops and up and down over and over again... is this an iac valve or what i just donno what it could be
any input appriciated
Rick
Old Aug 12, 2006 | 12:58 AM
rags2riches's Avatar
rags2riches
this could be a number of problems try checking these out:
a. ignition wire connection (could be loose)
b. fuel filter (could be clogged)
c. crompession loss in the cylinders (use an oil conditioner)
d. fuel injectors could be dirty (use fuel flush system)
e. loose spark plug wire or spark plug (running on 3 cylinders)
let us know if the problem persist
Old Aug 13, 2006 | 07:29 PM
fstop128's Avatar
fstop128
dont know if u r fuel injected or have a carb. if its the latter it could be the choke. unfortunately, there isnt alot of gen 3 advice here. try www.3geez.com if u cant find anything in a search here or u dont get many responses.
Old Aug 14, 2006 | 11:14 PM
4cylinder4ever's Avatar
4cylinder4ever
I believe your going in the right direction with the IAC. Try spraying some carb cleaner into the port inside the throtle body. If you look inside it you'll see a small peep hole on on side. BUT FIRST, you'll have to warm up the engine. turn it off and then spray away. when you try to restart it again you might get some hesitation. It'll be fine, because ounce it starts going again you have loads of smoke coming out too. let it burn the carb cleaner out itself...
and hopefully solve your problem. oh! since your in the throtle body I'd spray the inside of the intake also, you see what I mean.
Undertaker1064
CRX & Pre 92 Civic
3
Aug 29, 2006 12:03 PM
kartman2
21
Jul 30, 2006 07:18 AM
SirKaos
92+ Civic/EL & Del Sol
Jun 8, 2006 07:01 AM
curls
4
Aug 11, 2004 09:23 AM
JoJa15
2
Aug 19, 2002 05:11 AM
