help!!!!!! big problem
Old Aug 11, 2006 | 06:26 AM
mooze's Avatar
mooze
Default help!!!!!! big problem
today i was messing with the wire harness on the drivers side in my cousins 93 accord and now the passengers window wil not go down nor will the drivers door stay locked. help please!!!! i think its a broken wire. if so how do i fix it?
i cut the blue/green wire but i put it back together. the window still does not go up
Old Aug 11, 2006 | 06:33 AM
Blindside's Avatar
Blindside
Stealth Mode
have you checked for any blown fuse? maybe... could have been a short somewhere
Old Aug 11, 2006 | 11:00 AM
prostang460's Avatar
prostang460
This would be the first thing I would check too. You could've snapped the fuse or a relay if that was a hot wire that you cut.
Old Aug 11, 2006 | 04:38 PM
stereo's Avatar
stereo
just check the plugs on the harness to make sure it's plugged in tight and none of the pins have backed out. and if no fuse is blown . it's off to the pro's as you don't want to cause more damage trying to fix it
Old Aug 11, 2006 | 07:57 PM
sleezye's Avatar
sleezye
its always good when they start with i cut this wire dont go cutting wires next time
Old Sep 4, 2006 | 06:26 PM
WiLL Khrisi's Avatar
WiLL Khrisi
Default Need help on a sit.
I am having problem on my 93' H22. Wondered if you can help?
SLWalsh
92+ Civic/EL & Del Sol
2
Oct 3, 2006 05:59 AM
Undertaker1064
CRX & Pre 92 Civic
3
Aug 29, 2006 12:03 PM
kiddcarbuff
3
Dec 3, 2005 11:08 AM
Mike Oxbigger
Apr 17, 2004 02:27 PM
