'02 Civic EX acceleration/deceleration problem
Old Sep 16, 2005 | 11:50 AM
SLWalsh's Avatar
SLWalsh
Default '02 Civic EX acceleration/deceleration problem
A couple weekends ago, I started experiencing a problem concerning my car (2002 Honda Civic EX) - which I've been told isn't really a problem. (?!)
After startup, the car would suddenly - with my foot on the gas - decelerate. It was seem like it's stalling, but would then go back to normal after a few seconds. Another minute would pass with this problem continuing throughout. Finally, the problem would stop and the car would be fine......and the problem would not occur again until I shut the car off and start it up. And even then, it would not occur every time I started up, but maybe a few startups later. So it's mainly a startup problem, as the car is OK after I've driven it about a mile.
Also, I've noticed in the last several days the car now shakes after startup (sometimes while I have the car still in park) and I've needed to shut the car off to make that problem go away (but it would still "stall" and decelerate for that minute or so of driving).
I've taken it to 3 mechanics - one of whom was able to hook a computer up to the car - and after checking the car and the systems they've all said (a) they don't know what's wrong (2 of them were able to experience the problem upon start up), (b) they've never seen a Honda do this before, and (c) it's actually not a serious problem.
My "check engine" light came on once, and that was because - for a time - I was pressing down on the gas hard whenever the deceleration would start and the car would resume acceleration; I brought it to a mechanic (the one with the computer) soon after.
What kind of thing would cause this? I've heard lots of explanations - loose sparkplug, fuel injector, transmission - but I keep experience the problem and keep thinking, if it goes on for much longer, it *will* be a serious problem sometime down the road.
Thanks for whatever help you can provide. Hopefully I'll have a list of things the next time I go into the shop...
Sean
Old Sep 16, 2005 | 02:09 PM
97civicEXVTEC's Avatar
97civicEXVTEC
try changing your oil plugs an wires.. see if that makes any difference
Old Oct 3, 2006 | 05:59 AM
SkidooSteve12's Avatar
SkidooSteve12
01 Civic EX
I am having these same problems with my 01 Civic EX. I have found that if I just start the car up and let it idle for a few minutes that I don't have the stalling problem. But if I am in a hurry and just start the car up, let it idle for 10 seconds and then put it in Drive, that's when it does the stalling for about a minute and then clears up. I have about 120,000 miles on the car, original owner, NO mods, just replaced the timing belt, water pump, spark plugs, air filter, oil change, air conditioning filters, transmission fluid changed, fuel injector cleaner in the gas tank, bought gas at several different gas stations... still acts up.
I figured I'd do some online searches before taking it to the dealer, so after reading on here I'm going to get some Throttle Bottle spray cleaner tonight and try that. I'll also check the battery to make sure it still has a green "eye" because the battery is still original.
Any other suggestions?? I was figuring it was a fuel pump issue since the car doesn't have a "normal" fuel filter.
Thanks!
