5th gen washer camber kit???
Old Jul 19, 2006 | 11:15 PM
ColeM's Avatar
ColeM
Banned
Default 5th gen washer camber kit???
sumone said u can use washers to fix ur negative camber how so?
Old Jul 20, 2006 | 01:39 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
only for the rear... use them where the upper control arm mounts to the wheel well, very simple and effective. If the car is lowered a lot, you will need longer bolts as well, be sure to use at least grade 8 bolts for strength.
more washers = more camber correction
Old Jul 20, 2006 | 08:49 AM
wedley2's Avatar
wedley2
bboy Wesley West
yea, i have a 2 inch drop for my rear on my cb7 and two washers have corrected most of it
ColeM's Avatar
ColeM
Banned
thanks that way ill get ingalls for the front
Old Jul 23, 2006 | 07:10 PM
dleccord's Avatar
dleccord
and you are still using the same bolt? anyone know the bolt size or ring size for correction? dont want to take mines off at pepboys just to measure.
Old Jul 24, 2006 | 01:48 PM
wedley2's Avatar
wedley2
bboy Wesley West
yup, same bolt...worked fine for over a year
