Help 1996 Accord (Blinkers aren't working)
Old Jul 19, 2006 | 07:16 AM
ihsva's Avatar
ihsva
Default Help 1996 Accord (Blinkers aren't working)
Hi,
I am new here, but have been lurking for a while. It’s a very informative forum.
I purchased a 1996 Accord a few weeks ago, and just recently, the blinkers (turn signal lights) stopped working. The hazard lights are working fine, so I know the bulbs are fine. I also checked the fuses and they’re all fine.
Any idea what is might be? What the fix can be?
Thanks in advance.
Old Jul 19, 2006 | 08:23 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Check the actual lever on the side of the steering column.
Old Jul 19, 2006 | 09:01 AM
ihsva's Avatar
ihsva
thanks for your reply. But what is it I should be looking for exactly?
Thanks
Old Jul 19, 2006 | 09:04 AM
totalimmortal
MalleusMaleficarum
Well, to truly check it you'll need a helms and a mulitmeter to test continuity between the terminals. But you can spot check by just checking from any broken tabs that may cause the blinker stick to not contact correctly. I had to replace my wiper lever because the tab that held the two pieces together broke.
Old Jul 19, 2006 | 09:12 AM
ihsva's Avatar
ihsva
Do I have to remove anything first? Thanks
Old Jul 19, 2006 | 09:17 AM
totalimmortal
MalleusMaleficarum
Yea, the steering wheel top and bottom cover. Should be held on by three phillips screws on the bottom and then it pulls off. The lever itself should be held in place by three or four baby screws(philips) and a wiring harness that will need to be unplugged. After that, just check that nothing moves in a way it shouldn't. It will be pretty obvious if it's broken.
Old Jul 19, 2006 | 09:31 AM
ihsva's Avatar
ihsva
Thanks alot. I will do that once I get home today.
I heard that it might the flasher relay. does that makes any sense at all?
Old Jul 19, 2006 | 10:12 AM
totalimmortal
MalleusMaleficarum
Yea, should be under the hood.
