1989 Accord - Starting Issues When Hot - Stumped!
Old Jul 6, 2006 | 03:28 AM
avbunyan's Avatar
avbunyan
Default 1989 Accord - Starting Issues When Hot - Stumped!
Hi gang - I've got a 89 Accord I bought from a honest Honda mechanic did a wonderful job of fixing up - runs great!!! New starter, battery, distributor, main relay switch, good alternator - but...but... we can't figure out why after running for a while I would stop at a store, etc. and when I go to start it sometimes acts like the battery is weak and won't quite turn over but it always does - doesn't do all the time - cranks perfect in morning to go to work - cranks fine when I get in to go home but after running and stopping and then starting again it sometimes dddrrraaagggsss! The Honda mechanic did a read out of a computer from his job that appeared to be a starter but after changing out again it still does it!
Both of my good mechanics are stumped!
Thanks for any tips -
God bless
Old Jul 6, 2006 | 06:26 AM
Big AL's Avatar
Big AL
Swollen Member
I'm not too familiar with the 3rd generation accords but you didn't mention anything about replacing the coil. Have you tried that?
Old Jul 6, 2006 | 07:42 AM
fstop128's Avatar
fstop128
try www.3geez.com a forum for your gen of accord.
it does sound like the main relay if it does it only when its hot outside. check the contacts on the relay... u dont mention if its carb or fuel injection..
could be the starter contacts. bad cell in the battery. check your battery cables see if they r loose. check also at the connection to the starter.
how old r your plugs, wires, rotor button, coil and ignitor? when mine did a smiliar thing it was a valve that was out of adjustment.
Old Jul 6, 2006 | 07:57 AM
avbunyan's Avatar
avbunyan
1. it does sound like the main relay if it does it only when its hot outside. check the contacts on the relay...
2. u dont mention if its carb or fuel injection..
3. could be the starter contacts.
4. bad cell in the battery.
5. check your battery cables see if they r loose. check also at the connection to the starter.
6.how old r your plugs,
7. wires, rotor button,
8. coil and ignitor?
9. when mine did a smiliar thing it was a valve that was out of adjustment.
Thanks for input
1. Already been changed
2. Fuel inj
3. New starter - less than week old
4. New batterry - replaced in march - old one did have bad cell
5. Appear to be ok
6. Will check - good idea
7. Rotor button replaced -
8. Not sure about coil
9. My main mechanic mentioned valve
Thanks again
Old Dec 4, 2008 | 08:56 AM
RedsoxFan71's Avatar
RedsoxFan71
put a cold damp towel over the coil pack when its really hot outside....wait a lil bit the car will start
