Battery Light on 90' accord
Old Apr 21, 2006 | 11:01 PM
tour90's Avatar
tour90
Default Battery Light on 90' accord
I was driving on 520 today when my car died. My battery light came on on Monday and was on and off so I couldn't pin point the problem. So I kept on driving till today (Friday) when it died. I'm not quite sure what the problem is because the light would go on then off. Have any of you guys had this problem? I don't know if it's a loose connection with my wires or that my alternator is going bad. any input would be great.
Old Apr 22, 2006 | 04:03 AM
Cousin It's Avatar
Cousin It
Could be a loose connection, dead battery or bad alternator. Jump it off another car and check the voltage at the battery with the lights on. Better yet, if you can get it to an AutoZone they can load test your charging system for free.
Old Apr 22, 2006 | 07:30 AM
tour90's Avatar
tour90
ok, so i went to shucks and had a test done there. the employee that worked there said that there was charging problems. Loose wires or bad alt.?
Old Apr 22, 2006 | 06:53 PM
tour90's Avatar
tour90
well, the car died again. stupid battery light keeps coming on and off. what are the chances it's wiring or just a really bad alternator?
Old Apr 22, 2006 | 06:59 PM
fstop128's Avatar
fstop128
the light usually but not always means alternator.
Old Apr 23, 2006 | 12:05 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Well it couldn't be any easier to check for both, so you can probably tell yourself if you spend about 5 minutes on google and with the car.
Old Apr 24, 2006 | 06:21 PM
stereo's Avatar
stereo
I would guess it's the alternator as the battery light is wired directly to the alternator . most likely the brushes are worn to nothing, easy to check just pull the brushes off and check and replace them they are like $25 new I had the same thing happen and brushes fixed it . especally if it's orginal alternator!
Old Apr 24, 2006 | 07:55 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Pull the alternator, take it down to Schucks and have it tested.
I bet money your alternator died.
Old Apr 26, 2006 | 10:38 AM
marc96accord's Avatar
marc96accord
Banned
altenator
Old Apr 26, 2006 | 01:04 PM
stereo's Avatar
stereo
if the light is out at the time of testing I would bet it would check fine... the simple thing would be to pull the brushes if they are both clean then it's ok if one side is dull then it was arcing on that side .
