Coolant leak at the back of the engine?
Hey guys just the other day i replaced my inter heater hose because it busted on my( hose just below the distributor) and i replace it with no sweat and now i have a leak to what seems to be coing out the back of the engine coming and dripping off the oil pan, i would think it might be the water pump but i can see the leak coing from what seems to be the timing belt location but it drips from a higher part of the engine( not around the water pump location) near the top of the timing cover? any clues, is there a hose back in there or back there that can be the issue?
bboy Wesley West
there is a hose back there...if you look above the oil filter, you'll see a black pipe that actually goes from one end to the other (from thermostat to water pump? idk...)
but there is also a hose that attaches from that to the heater i believe.
also if you look at the far engine, try looking for that black pipe...
