hello and a few questions
Old Apr 5, 2006 | 11:44 AM
ayalcin's Avatar
ayalcin
Default hello and a few questions
Hello all, I have been browsing for a while and just registered. Today I took my 96 105K Accord LX to the honda dealer for emmisions warranty extension service which includes pretty much a free tune up. They also found out that my oxygen sensor was faulty and said they would replace it covered by the warranty.
Before I took it there I knew that my valve cover gasket and spark plug tube seals were leaking and was planning on replacing them which I found out is fairly easy and are just under the valve cover.
Well... in addition the dealer said that I would need the "cam tower seals" (I have no idea what these are) replaced which requires removing the cam since they are way "down there". They quoted me a price of 339$ to replace all these seals. The OEM valve cover gasket kit includes the gaskets except this cam tower seal and is only $35. Is this a fair price and where are these cam tower seals and how hard are they to replace when you have the valve cover off?
They also said that I need to replace my distributor subassembly for $395 and somehow oil was getting in there....
They also found:
leaking oil pan gasket $279 (and possibly another $850 if they find any thing else there)
a leaking power steering pump for $195
and timing belt replacement for $529 (which I know I need but I was quoted $200 by another shop)
well, all this is very expensive and I am a little shocked in teh sense that my car drives just FINE. I would like to be able to tackle some of it myself after I am convinced that these are real problems. Any advice or opinions?
Thanks
Old Apr 5, 2006 | 11:59 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
They also found:
Thanks
Well welcome and WOW thats alot of money....Have them do the cam seals...should have them do the timing belt at the same time, since you have to take the cams off....Timing belts are iffy so get them changed and there regular intervals, it will save you in the long run trust me...the PS pump..Dizzy..and Oil Pan can be done yourself
Old Apr 6, 2006 | 02:57 AM
Fkatz's Avatar
Fkatz
yeah oil pan is easy just some bolts and a gasket that shop that qouted u 200 dollars must be in an alley but if u trust them have them do the cam seal and the timing belt cuz lk the post above me said do both save u money in the future the distrubuter u could probably do too go to the junkyard and get 1 but search how to put on the distributer cuz if u don't put it on correctly then u got problems
