Help! Speedometer problem
Old Mar 31, 2006 | 08:08 PM
Denare's Avatar
Denare
Default Help! Speedometer problem
This is the second time posting a thread about this, I've been having a problem with my speedometer, everything else works fine the only problem is that i can't tell how fast I'm going, also when the speedometer works then the odometer also works. I found out that the problem is coming from the cluster not from the cable or speed sensor, because when i press the trip reset button it will start working again. Does anyone know how I can fix this problem?
