whirrling noise
Old Mar 20, 2006 | 07:49 AM
scarface21's Avatar
scarface21
i did, i tried to move the the hub and there was no play. I spun the wheel and it turns fine only a faint shhh shhh
Old Mar 20, 2006 | 07:50 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
There's no problem there then, you'd be able to tell if there was play.
My vote is on an unbalanced wheel...hit anything recently that might cause a weight to fall off?
Old Mar 20, 2006 | 07:54 AM
scarface21's Avatar
scarface21
I'll go get the the tire checked, balanced if needed. Hope that is the problem. thanks alot for you help
Old Mar 20, 2006 | 07:57 AM
98CoupeV6's Avatar
98CoupeV6
No problem. I wish I could say for certain but my guess is an unbalanced tire vibrating at an audible frequency, since you said the bearings are fine. FYI, rear bearings typically take 30-60k more miles to go than the fronts on FWD cars.
