Transmission Flush Procedure, work for 6th gen Accord?
Originally Posted by flyromeo3
Could I drain and re-fill it on the first two times with the same fluid?
Then the third will be fresh new one?
You need the new fluid to mix with the old stuff that's stuck in the torque converter. That's why you drive around between drain/fill cycles.
If the fluid that drains out is pretty clean, then just don't bother draining again. If it's really dirty, maybe drain & fill more than 3 times until it comes out clean.
Imagine a bottle that can only be drained 1/2 way. How many times will you drain & fill it before it's clean enough to drink??
