E-Brake and CV Joints
Old Mar 5, 2006 | 04:13 PM
tour90's Avatar
tour90
Default E-Brake and CV Joints
I'm still a noob, but I've been searching for a while to see how to tighten my e-brake because there's some lag, and how to replace my cv joints on my 90 accord.
So far I haven't came up with anything I was looking for.
Old Mar 5, 2006 | 05:26 PM
texaskreek06's Avatar
texaskreek06
Default Me Too!!!
I also need help and information on replacing my 93 accord cv joints... Thanks!
Old Mar 5, 2006 | 06:28 PM
jschmid's Avatar
jschmid
I would recommend replacing the entire axle with a remanufactured axle. It'll cost you about $60-75 after returning your broken one. You won't have to mess with disassembly of the joint, packing the boot, etc.
You might find some good DIY write up on the board, but here's the basics:
Remove wheel, unstake and remove axle nut, release lower ball joint, swing the spindle outward so the axle has room to come out, might have to hammer the axle out of the hub, use a large flathead or prybar to remove the axle from the tranny.
To put the new one in, slide it into the tranny, making sure it's all the way in and the ring clip is secure. then swing the spindle back out to let the axle slide into the spindle. Once axle is in, put on the new axle nut, reattach the LBJ, torque to spec, stake the axle nut.
Old Mar 5, 2006 | 07:37 PM
Driverman5777's Avatar
Driverman5777
Get a Haynes or Helms manual.
