f22b2 oil leaking
Old Feb 22, 2006 | 04:05 PM
accordsir86's Avatar
accordsir86
Default f22b2 oil leaking
ok so for the past week i noticed iam leaking oil. 1 drop maybe every 2-3 days or so. this friday is the only day that ill have time to get under my car and check out whats wrong and where its leaking from, so i put a quart of oil today, which raised it from low to normal again cus of the leak, and i remember i put my filter on tight, but not too tight, and my drain plug is on tight from the last time i changed my oil. any suggestions as to what it might be before i get under it friday? iam thinking maybe oil pan gasket needs replacing, or something even more serious.
any help appreciated.
Old Feb 22, 2006 | 05:17 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Uh okay so where is it leaking from?
Old Feb 22, 2006 | 05:57 PM
accordsir86
not sure where its leaking from right now. thats what ill be looking for later in the week. as of right now all i know is that the oil filter is on tight and the drain plug isnt leaking anything.
Old Feb 23, 2006 | 05:18 AM
98CoupeV6's Avatar
98CoupeV6
Well since we can't get under your car and look at it for you you'll have to figure it out. When you find out the spot it's coming from we can help you fix/replace whatever gasket or seal is bad. Hopefully it's not a head gasket or oil pan gasket, those aren't fun.
