Accord 2000 - Horn Problem.
Old Jul 29, 2008 | 03:20 PM
B SQUEEZE's Avatar
B SQUEEZE
yeah grab the srs cable reel, its something like $60. its easy to install, just pull the wheel and unhook the existing reel, pop the new one on, plug everything back up and your good
Old Jul 29, 2008 | 03:56 PM
webie's Avatar
webie
Originally Posted by DOZ5
I attached schematics for my 1999 EX V6. You should have yours from the hayens manual. If you don't have a manual like the Hayens, you should get one.
Any way, Have someone help you with your troubleshootings.
To rule out your horn, take a wire and hook the horn directly to positive. Then you know the horn works.
Check the relay in the underhood fuse/relay box. For location of relay number 10 horn see attached. When the car on you should at least hear it click. If it clicks but no horn it might be bad.
Since the horn switch goes through the sterring column, I would bet the problem is the cable reel. Id different sterring wheel positions you should see different resualts.
Take a volt meter, measure 12v on the horn while somebody press the horn switch. WEAR EAR PLUGS. If you dont get around 12 volts there the problem is elsewhere.
From the schematics you will see that there are other circuits connected to the cble reel. Ignore those. and assume they work fine until you work your way up to the cable reel.
A cable reel can be purchased by it self. There is a procedure for replacing it because of the air bags SRS system.
If you need have questions please ask after you document EXACTLY how you approched the problem and what you did.
Good luck!
I think It's definitely the "srs cable reel" as I have tested most relays and circuits. I just learned to live with the problem. For me, most of the time it's working; but there has been times when I really needed it and it didn't worked. Lucky for me I have escaped all bad drivers out there!!!
I have the Service Manual but I could not find anywhere how to replace this part (srs cable reel). Are you sure that a cable reel can be purchased by it self, and there is a procedure for replacing it? (This is for a 2000 Accord 4cyl)
For example, I recently had an oil leak on the "Distributor" inner o-ring (the one inside the distributor rod). A friend of mine who is Honda/Acura mechanic told me that on most previous Honda models this was an easy part to replace. But in my case there was no way to get into the inner o-ring. I had to buy almost the complete "Distributor" (obviously without cap, ignition, and other electric parts).
Maybe this "steering column" / "cable reel" issue is the same as above. Maybe Honda made it to difficult to replace the "cable reel" that you need to buy the complete "steering column".
Just in case, I couldn't find the "srs cable reel" as a stand alone part in MH.
Old Jul 29, 2008 | 05:18 PM
B SQUEEZE's Avatar
B SQUEEZE
its sold by itself, i had my body shop order it because i suspect they are the ones that broke it, its a piece of cake to install, i watched the guy take 5 minutes to do it...
Old Jul 29, 2008 | 05:22 PM
B SQUEEZE's Avatar
B SQUEEZE
bam!
http://cgi.ebay.com/ebaymotors/98-02...spagenameZWD1V
Old Jul 29, 2008 | 06:43 PM
vtec4clyfury's Avatar
vtec4clyfury
Geese!
99% of the time a tech will refer to this as a clock spring as most car manufactures do too. I was about to say the same thing when you said you couldn't find the cable reel.
Old Jul 29, 2008 | 07:35 PM
webie's Avatar
webie
Did it solve the problem?
I just found the part in MH. It's $45.60 without shipping. Although the service manual does not specify the removal/installation procedure. Looking at the part, I think it should be easy (with the right tools).
But, if this is the solution to our horn problem. Why in the $#$%#% the Dealer wanted to change the complete "steering column"?
Just to make more money??? :rant:
Old Jul 30, 2008 | 04:03 AM
B SQUEEZE's Avatar
B SQUEEZE
dealer wants to make more money, good thing you are educating yourself on it, yes it fixed my horn problem, and my cruise control problem
Old Jul 30, 2008 | 04:43 AM
DOZ5's Avatar
DOZ5
In this case, I would buy this part new!
The reason is that malfunction in this part would cause the steering wheel air bag to NOT deploy. I will look for a procedure to change it if I can find it.
Old Jul 30, 2008 | 05:32 AM
DOZ5's Avatar
DOZ5
Default Cable reel replacement procedure
Here is the procedure attached.
Old Aug 4, 2008 | 10:35 AM
shipu7la's Avatar
shipu7la
Thank you for your post. I took the car to my machanic with the Reel cable from honda dealer and after changing the cable, horn is working fine. I also added some conductive grease to the grounding cables at the end of the column (just in case that is the problem). That concluds my horn problem.
Thank you all for your posting.
-Bill.
