Is there anything wrong with?
Old Dec 3, 2005 | 08:04 AM
jordanhxc's Avatar
jordanhxc
Default Is there anything wrong with?
Is there anything wrong with taking out my air box resonator and just strapping in the the filter on my 2000 accord?
Old Dec 3, 2005 | 08:49 AM
shonnv's Avatar
shonnv
7th Gen Coupe V6
what exactly are you asking???? What kinda filter???
be more specific
Old Dec 3, 2005 | 08:52 AM
jordanhxc's Avatar
jordanhxc
just taking out the entire resonator, and strapping the stock filter to the top part that goes to the engine, it needs to be straped because the filter would be on the bottom seeing as the box it usualy sits in would be gone
Old Dec 3, 2005 | 09:10 AM
jschmid's Avatar
jschmid
You can remove the resonator without removing the lower part of the box that holds the filter.
Is there anything wrong with it? No, it likely won't hurt anything. Might increase flow, it'll be a bit louder. Might be more succeptible to sucking water up but I'd say it's probably not a big deal.
You won't be the first to do it if it makes you feel any better.
Old Dec 3, 2005 | 02:10 PM
jordanhxc's Avatar
jordanhxc
yeah the water is the first thing that came to mind, and yeah i know im not the first i didn't think it up, i read it somewhere, I just wanted a second opinion...thank you
Old Dec 3, 2005 | 03:16 PM
with my SRI, I removed the resonator for a week ... not good. I could feel the engine bog.
Old Dec 3, 2005 | 06:43 PM
jschmid's Avatar
jschmid
By SRI I'm assuming you mean an aftermarket intake...what system? I know the V6 is different, but I don't see how the resonator would affect an aftermarket intake.
Old Dec 3, 2005 | 06:47 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
the actual resonator is inside the bumper and can easily be removed without changing the air box or modifying it.
Old Dec 3, 2005 | 07:57 PM
I tried this in the middle of summer and it wasn't good.
With the SRI, I could always hear a sucking noise when I'd press the accellerator. Without the res, the sound was completely gone. I could feel the engine bog though the entire powerband too. Red light stops = strange idle also.
The V6 res is a gigantic J pipe. It really does make a difference.
Old Dec 4, 2005 | 11:49 AM
jschmid's Avatar
jschmid
Interesting...thanks for the reply
