how to ajust 2000 ex clutch pedal and smooth shift
i have a 2000 coupe....but the clutch pedal is too high.anyone know how set it lower a lil bit?i just learn to drive stick....and every time when i shift from 1 to 2 ....the car shake suddenly...how to reduce the shake?how many RPM you guys change the gear......futhermore,when i will know the clutch need to change?thx....
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
Honda uses hydraulic clutches (as opposed to a standard mechanical spring loaded setup), so they are self adjusting with no adjustments that you can make.
You will know when it's time to change..... it will start to slip like crazy.
