fuel pressure issue (possibly)
Old Oct 26, 2005 | 06:54 AM
kmcaprice14's Avatar
kmcaprice14
Default fuel pressure issue (possibly)
The other day, I was backin into my garage and my 94 accord lx (f22b2) 5sp stalled out on me. As I have never owned an automatic in my life, I was a bit suprised to stall... especially as I was fairly certain that the clutch was in all the way when it happened. Either way, it took a good minute to restart the car. It cranked fine, but it seemed like the engine wasn't getting any fuel. It reminded me of an old american car getting flooded if you give it too much gas. I know this is not the case, but for people who have experienced this, they'll knowthe type of thing I'm talking about. Anyway, it started back up and has been running fine. In the mornings it has taken a few seconds longer then usual to start. It still starts fine, but takes just a bit longer to be noticable. I filled up the tank and the problem almost went away. My thought is that it could be a fuel pump on its way out.... does anyone else have any other ideas? By the way I have 182,000 miles on all stock components (nothing major ever been replaced), and have religiously done all oil changes, and tune ups myself.
Old Oct 26, 2005 | 08:03 PM
kmcaprice14
any insight?
Old Oct 27, 2005 | 06:01 PM
RedThunder's Avatar
RedThunder
last fuel filter change?
I'd carry a spare main relay with me, if I were you. You're near the mileage and age that they get a bit iffy. That will kill fuel and or injector pulse on startup when they act up.
Without seeing the car, it's kind of difficult. No check engine light on? Just for kicks, jump the scs and see if it flashes out any codes.
Old Oct 28, 2005 | 05:04 AM
JiggaD369's Avatar
JiggaD369
check your ground connection on the fuel pump.
Old Oct 28, 2005 | 06:26 AM
Tanker's Avatar
Tanker
Probably sticky injectors.
I once had a bad fuel injector on a VW at high mileage and fuel injector cleaner helped; I've used it regularly, twice a year, ever since.
Old Oct 28, 2005 | 06:30 AM
skip259's Avatar
skip259
could it have been just dirty gas or water in the gas? I'd put a bottle of techron fuel system cleaner in the car,fill the take, drive on the highway for a bit. maybe not go tooo far, but just go at speeds to keep the rpm above 2250 or so.
