fogging problem on diy black housing?
Old Oct 12, 2005 | 07:39 AM
azianstylez's Avatar
azianstylez
Default fogging problem on diy black housing?
Would there be fogging problems on diy black housing since u'r breaking the seal to paint the covers??
Old Oct 12, 2005 | 08:18 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Yes if you didn't seal it very thoroughly with Silicon.
Old Oct 12, 2005 | 10:14 PM
XprincoX's Avatar
XprincoX
"you wanna die??"
yeah make sure u reseal them with silcone and you should be fine
Old Oct 13, 2005 | 05:10 AM
lots and lots of silicon.
Old Oct 13, 2005 | 09:08 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
silicon is said to prevent any liquid from leaking in, and vaporizing inside the head light when the lights are one, and have no plave to evaporize to.
seal it up good at first, you shoulnd't have this problem..
but if you do..
take out the light bulbs and put 3 hair dryers to the bitch.
Old Oct 13, 2005 | 05:00 PM
jschmid's Avatar
jschmid
I don't see why people add silicone. I've done 3 sets now and never had a problem. Didn't remove any factory glue, and when resealing, heat around the junction so the glue is nice and soft so you can completely re-approximate both pieces (pliers work great), you'll have a great seal, and it'll look oem.
Here's the latest set I did, after re-sealing:
File Type: jpg
File Type: jpg
Old Oct 13, 2005 | 05:02 PM
98CoupeV6's Avatar
98CoupeV6
I believe it's from the 'better safe than sorry' archive h:
Old Oct 13, 2005 | 08:03 PM
azianstylez
on a 97 accord, do u need to take the bumper off to take off the ligh housing?
Old Oct 13, 2005 | 08:09 PM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
yes i believe so
Old Oct 13, 2005 | 10:27 PM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
yes you do.
infact, i havn't seen any headlight that comes off with out taking your bumper off.
