Header HELP~!!!
Old Sep 17, 2005 | 06:22 PM
quantumR2's Avatar
quantumR2
Default Header HELP~!!!
Hi I own a 97 accord F22B1 and am in the process of replacing my headers to DC Sports ones. The problem I am having is that I dont know how to take the upper part of the header from the collector pipe. I can't get a 1/4 drive in there and dont want to take off the front engine mount. This is extremely frustrating and time consuming any help would be appreciated thanks tunerz.
Old Sep 17, 2005 | 10:37 PM
accordsir86's Avatar
accordsir86
i dont understand your question...do you have any pictures? i put in a dc header in my brother in laws 97 accord and it wasnt too hard. iam not sure exactly what part you're having trouble with.
Old Sep 18, 2005 | 01:51 AM
quantumR2's Avatar
quantumR2
I'm having trouble taking the header itself out I can't seem to get a socket small enough to fit in the engine bay to get at the three bolts that connect the upper part of the header to the lower collector pipe so I can take it out. matter fact, how do you take out the header once you've dissassembled it from the block and the cat?
Old Sep 18, 2005 | 02:07 PM
cconfusionn's Avatar
cconfusionn
last time when i installed my DC sports header, I went under the car and used the extension bar to take the three bolts which i assumed u mean the three bolts that connect from the actually header to the collector pipe. Next i took the bolt off from the collector which is next the the converter if u have a 94 or 95 or converter itself for 96-97. Then i took that part off. then next i took the header off. good luck
Old Sep 18, 2005 | 04:07 PM
wedley2's Avatar
wedley2
bboy Wesley West
i went under as well for my 4th gen install.
Old Sep 18, 2005 | 04:48 PM
apexivtecaccord's Avatar
apexivtecaccord
ITZJDM
you do not have to take off the motor mount just get a long extention and a 14mm and it should come right off use a 3/8" drive to
Old Sep 18, 2005 | 07:05 PM
accordsir86
how did i take it out after its off the motor itself, i guess you can jack up your car high enough to slide it out from under the engine bay. although i havent tried that method yet, it should work. i always use my uncles lift in his garage, makes shit a whole lot easier!!
Old Sep 19, 2005 | 12:23 AM
quantumR2's Avatar
quantumR2
Thanx all, all your suggestions were taken and all helped got it done thanx to ya'll
