Accord Tire Help
I would recommend you purchase the same type of tires as TireRack recommend for the Accord '03 6-speed OE tire. This will keep your speedo accurate and provide a good ride and All season grip, until you decide what tire to buy.
You may want to simply reference the same tire size as the 6-speed and get a better tire like V or Z rated Yokohama ES100.
Originally Posted by shonnv
But dont you need the Camber Kit, New Shocks and all that stuff for the drop? and how about the Ride Quality does it get rough or smooth after the drop.
Ok so I guess I have to change them cause I do corner hard. Any other reccomendation then?
I want to spend about $450 for the tires and I might do the drop as well. I was looking at some Tein H-Techs which are around $160. I dont know where u get them installed though cause most of the shops I've been to, they dont install customer parts.
2 things that always terrified me about lowering was
1> alot of Money and
2> bad ride quality.
I bought a V6 over 4Cyl cause I wanted a smoother car but if a mild drop doesnt change that, then I guess I will do that.
How much does it cost to get the springs installed.
Don't know really where to address this question, but i have 215/40ZR17 Sumitomos on my car and the max pressure on the tire says 51 psi, but i'm not sure what the best pressure to have in them is for my specific wieght, etc. Can anyone help or offer any suggestions? I'm not even sure where else to look...
