Fuel Pump
Old Sep 1, 2005 | 08:16 AM
91Honda_Man's Avatar
91Honda_Man
Default Fuel Pump
Is there anyway to change the fuel pump on a 91 Accord without having to remove the fuel tank?
Old Sep 1, 2005 | 09:03 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
No. Here are the instructions for the 90-93 Accord:
1) Relieve the fuel pressure.
A) Disconnect the negative battery cable.
B) Remove the fuel tank filler cap.
C) Use a box end wrench on the 6mm service bolt at the top of the fuel rail, while holding the special banjo bolt with another wrench.
Fuel Rail
Place a rag or shop towel over the 6mm service bolt and SLOWLY loosen the 6mm service bolt one complete turn.
2)Remove the fuel tank.
Fuel Pump Assembly Removal
3) Disconnect the fuel lines and connector.
4) Remove the fuel pump mounting nuts.
Reverse procedure to install. Torque fuel pump mounting nuts to 4 lb-ft (6 Nm). Torque fuel line bolt to 20 lb-ft (28 Nm).
Replace washers as shown in the illustration. CAUTION: Do not attempt to disassemble the fuel pump, it is not designed to be field serviced.
Removing the fuel tank:
1) Relieve fuel pressure.
a) Disconnect the battery negative cable from the battery.
b) Remove fuel filler cap.
c) Use a box end wrench on the 6mm service bolt at the fuel rail, while holding the special banjo bolt with another wrench.
Fuel System Service Bolt
d) Place a rag or shop towel over the 6mm service bolt.
e) SLOWLY loosen the 6mm service bolt one complete turn.
2) Block the front wheels. Jack up the rear of the car and support with jackstands.
3) Remove the drain bolt and drain the fuel into an approved container.
4) Disconnect the 3P connector in the trunk.
5) Remove the two-way valve cover and the fuel hose protector.
6) Disconnect the hoses. CAUTION: When disconnecting the hoses, slide back the clamps then twist the hoses as you pull to avoid damaging them. Clean the flared joint of the high pressure hoses thoroughly before reconnecting them.
7) Place a jack or other support device under the tank.
Fuel Tank Assembly
8) Remove the strap bolts and let the straps fall free.
9) Remove the fuel tank. NOTE: The tank may stick to the undercoating. To remove, CAREFULLY pry it off of the mount.
10) To install, replace the washer on the drain bolt and assemble parts in reverse order.
Old Sep 1, 2005 | 09:04 AM
98CoupeV6's Avatar
98CoupeV6
Service spec for the tank is only a half an hour so it shouldn't be bad.
