fuel flappy thing missing
Old Aug 19, 2005 | 01:29 PM
2legit2quit's Avatar
2legit2quit
You Big Dummy
Originally Posted by kenton
My 98 had a "circle" that blocked the actual hole where the fuel went. Once you tapped it with the gas nozzle the "circle" retracted
Yeah, I thought all cars had those "circle" things, but a quick check of my '05 Tundra X-SP
proved me wrong.
Originally Posted by MrChad
If you knew how a fuel pump worked in the tank I find it hard to think anything like a small coin of metal would do jack it simply doesn't scavenge the tank like that.
You're right. Like you said, low fuel light probably burnt out and he probably ran out of gas.
Old Aug 19, 2005 | 03:49 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I still don't know what the hell you guys are talking about.
Both my Accord and TSX, have a ~"2 lets say filler neck pipe, the pipe then has a funnel type plate welded to the inner dia meter to hold the petrol filler tube.
And it's sized so that you can't fit a diesel filler tube.
Bottom line no moving parts, no flaps...what the hell could you brake off and loose in the tank. And your gas door locks, who the hell would syphin your gas without breaking into the car to unlock the door?
I have no clue what is going on in this thread......
Old Aug 19, 2005 | 04:00 PM
jschmid's Avatar
jschmid
I don't know if some Accords got these, my 99 never had one, but my wife's 97 civic does, here's a pic to give you an idea, my Accord, wife's Civic.
File Type: jpg
File Type: jpg
Old Aug 19, 2005 | 04:40 PM
Addicted2VTEC's Avatar
Addicted2VTEC
Diesel???
Old Aug 19, 2005 | 04:42 PM
Addicted2VTEC
Diesel? Who said anything about diesel???
Old Aug 19, 2005 | 04:51 PM
fstop128's Avatar
fstop128
the remote gas door can easily be broken into for thieves to take your gas..
Old Aug 19, 2005 | 05:53 PM
MrChad's Avatar
MrChad
That's the purpose of the small plate with the hole, to direct what type of nozzle, just as passenger diesel cars can't use a class 8 diesel fuel nozzle on account they can't accept the larger volume flow nozzle.
But to my knowledge the Accord's never had this flap that Schmiddy posted, at least none of the Four 6th gen model's I've driven.
Old Aug 20, 2005 | 10:51 AM
Dr. Reef's Avatar
Dr. Reef
UPDATE.
I've been driving it around. However, it won't start again. Another day of 100oF weather in SC and it isn't starting. This time the gas tank is completely full, having just been filled up yesterday.
I still don't have a metal flap to protect the nozzle hole like I used to. And half the people on here say they have one, half don't so I don't know what to make of that.
I guess it's time to check fuses with fingers crossed. But the fact that it started working again and has now stopped has me confused as shit.
Old Aug 20, 2005 | 11:11 AM
Dr. Reef's Avatar
Dr. Reef
It's not a fuse.
What do we have left:
-faulty fuel pump
-loose/faulty distributor
-defective fuel pump relay or harness at relay
Old Aug 20, 2005 | 07:50 PM
MrChad's Avatar
MrChad
We can feel your pain, but do you have a helms manual to trouble shoot with? Else a trip to the mechanic may be needed.
And I'm still not sure the 6th gen Accord ever had a "flappy thing?"
