Steering and suspension problem
In addition to a good inspection of everything, when you have the car jacked up, try and move the front wheels and tires by rocking them sideways and up and down. If they have some play in them, probably a ball joint. I had to replace an upper ball joint in my 99 Accord recently. Going over bumps it would make a small knocking noise, and if you drove very slow in a parking lot and rocked the wheel back and forth, you could hear it clanking softly.
Originally Posted by 98CoupeV6
Are you sure it's not bad struts or a bad ball joint?
Rack and pinion I tested when vehicle was still and engine off. When I’m moving steering wheel I can hear knocking which I hear when I drive over bumps. I’m more than positive that knock comes from rack and pinion.
I think I should replace end link first and later investigate a steering problem.
What is the way to test struts?
Ok, I got my vehicle today from dealership.
That's what they say:
Advised customer of repair/needs:
2 front sway bar link kits =$165.00
2 rear sway bar link kits=$195.00
2 inner tie rod ends =$377.00
Left outer CV boot=$189.00
front brake job w/rotors=$426.00
wheel alignment=$95.00
Total=$1447.00. :jawdrop:
I know that brakes can wait. It is not a time for them yet.
I checked inner tie rod ends and they were not loose. :hsdunno:
Also, I didn't notice leaking CV boot. I will check it tomorrow.
I decided to start with end links, CV boot, and I'll see if I really need to follow this list to the end.
How hard is to replace inner tie rod ends?
It's easy as hell to replace tie rods if you have an impact wrench...I don't so a friend of mine did mine for like $20.
The price on everything is pretty outrageous...you can do most of that yourself for 1/10 the price with some time, patience and a $50 Helms service manual.
Woah. Okay, you say you need to replace your left front endlink...how do you know you need to replace it? If it is broken, what makes you think that it's not the source of your problem?
