Transmission slips when accelerating out of a turn...
Old Jul 31, 2005 | 06:55 PM
ItsaHonda's Avatar
ItsaHonda
Default Transmission slips when accelerating out of a turn...
Perhaps this could be normal, but I've been noticing a lot lately that as I'm making a turn (without stopping) such as yielding on to another road and hit the gas as I'm still turning, my transmission will sort of give a feeling of slippage as it engages into gear. It doesn't do this any other time, and otherwise shifts fine. If I wait until I've made the complete turn and then accelerate, it will shift normally. Any ideas? Is this normal? I change the tranny fluid every 15k miles with Honda ATF, and just had it changed less than 5k miles ago.
BTW, the car is a 1996 Honda Accord EX 2.2
Old Jul 31, 2005 | 09:17 PM
thisismatt's Avatar
thisismatt
I guess the obvious would be to make absolutely sure the level is correct. You should be checking it on level ground with the engine off IIRC. Also, 15k intervals seems a bit excessive...
