Engine Noise
Old Jul 30, 2005 | 05:58 PM
ItsaHonda's Avatar
ItsaHonda
Squealing sound could be the sound of a new timing belt on an old tensioner. In my experience, the sound usually goes away after a few thousand miles after the new timing belt. I'm on my second timing belt, but the second time I had the tensioner replaced and didn't get the squealing like I did after the first. I also think my mechanic perhaps put the belt on a bit too tight.
Back to the engine racket, Mine happens just as you describe. Doesn't do it under harder acceleration (or at least I can't hear it... might just be shadowed by the sound of the engine itself) I mostly hear it when driving through parking lots or neighborhoods.. but I stopped paying any attention to it many thousands of miles ago.
Old Aug 15, 2005 | 10:03 PM
lk21joker's Avatar
lk21joker
AnotherAccordOwner
Originally Posted by AccordVT
I have a 94 Accord EX Auto 4cyl and for a couple years now it has been having a gradually increasing clank noise. In general it's pretty quiet but has been getting louder and at just a tiny tiny bit above idle it makes a clank noise. I beileve it's a valvetrain prob or adjustment but I'm not sure. Haven't adj. vales yet (prob should) HELP! The Car basically sounds like a diesel. Does anyone no anything about this noise?
It sounds like you have a problem with the valve timing. It's becoming inefficient for the air coming in and out when the valve is not at the correct timing. I suggest you have it adjusted at a bodyshop. It happened to my old 94 ex accord and 97 civic, luckily my friend is a mechanic and he fixed that for me, both cars.
Another case is the engine knocking, if you use lower octain gas than suggested in the manual, your engine will suffer a lot of knocking, and it will damage the engine over time. Just try higher octain gas and see what happens
Old Aug 16, 2005 | 03:10 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Is it possible to buy 85 octane gas in this country
