00 Accord Sway Bars, help
Old Jul 11, 2005 | 10:43 PM
CG5TougeMaster's Avatar
CG5TougeMaster
Default 00 Accord Sway Bars, help
I ordered eibach sway bars for my 2000 accord EX sedan...does anybody know if the front stock sway bar is under, or over the frame?
Old Jul 11, 2005 | 11:17 PM
wedley2's Avatar
wedley2
bboy Wesley West
just look under the car...?
Old Jul 12, 2005 | 05:38 AM
Vlad666's Avatar
Vlad666
I am not sure about 2000, but on 2003 it is over the frame. Put Neuspeed on about 2 months ago and it was a bitch to work on.
Old Jul 12, 2005 | 05:31 PM
CG5TougeMaster
so....in other words, you dont know.... on 98-02 it's under the frame
Old Jul 12, 2005 | 05:47 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
It's under the frame on the 98-02, it's actually a sub frame, the middle of the bar bolts on behind the front axle line(s). The bar is held in place on the ends with endlinks (smart name) and in the middle with rubber bushings.
Good luck getting the endlinks off the front lower control arms, I had to have Honda cut mine off. I didn't have a socket wrench that would allow me to remove the nut and still fix the end link rod with an allen key. I was actually bending allen keys so even if I had the mystical socket I was a bit hosed during my install.
Like others have said stick your head under the car would ya?!
Old Jul 12, 2005 | 07:33 PM
CG5TougeMaster
the reason i asked here is because i was in my pajama's, it was the middle of the night, and i didn't feel like finding a flashlight then getting on my back to peek under my low ass car. i was wondering so i thought i'd ask. if you dont know or dont want to answer, just read the thread and keep rolling. if i felt like looking under the car i would have done it.
Old Jul 13, 2005 | 04:35 AM
MrChad's Avatar
MrChad
Hey, don't flame my @$$ I gave you the answer. Unlike many technical question on this forum looking under your car isn't what I would call difficult.
Old Jul 13, 2005 | 05:49 PM
CG5TougeMaster
aiight man, mybad...i was in a bad mood lol anyway, anybody know how to get the end links off? the bolt connected to the sway bar just spins freely, im assuming there's a certain tool you have to use to get it off? anybody know?
Old Jul 13, 2005 | 07:06 PM
MrChad's Avatar
MrChad
This is what I tried to tell you. On the rear you hold the nut with an open end wrench\box head or crow foot head on a socket. To keep the endlink from spinning you use an allen key in the threaded body, this is why you need a wrench not a socket.
However, You would need a crowfoot socket head or similiar part to get down into the front nuts of the endlinks in the lower A-arms. I didn't have one, my threads also rusted up bad, so the dealer had to cut mine off at the a-arms and then installed new ones, they are cheap enough.
I would also install new rear endlinks if I were you too, Honda has a TSB and new rear endlinks for all 98+ Accords, TSX uses the same endlink so I figure it would need them too at some point. I have yet to replace my rear links.
