Help! The SRS indicator light stays on.
Old Dec 21, 2005 | 08:30 PM
Hot69Z's Avatar
Hot69Z
Thats alot of help, got the same problem in my civic but how do you decifer the code? i mean does anyone know the definition as to what is wrong when the code flashes?
Old Dec 23, 2005 | 08:35 AM
strykernyc's Avatar
strykernyc
today i was in my car and i went to look myself n the mirror then i notice right under the mirror it read, the srs system most be inspected after 10yrs from it was made.
Old Dec 23, 2005 | 10:27 AM
Nors's Avatar
Nors
倍力恋
Ten years after the SRS is installed it must be checked out. I am not sure if the light comes on or not for this check. On my 95 accord the light came on, I took it to the dealer, they removed the light, I don't rember the cost.
Old Dec 23, 2005 | 02:26 PM
georgie's Avatar
georgie
mine came on and i had Honda scan it for code and it came up as faulty passnger airbag circuit. i am gonna check all wring to pass airbag and see whats up. i have new bags and module due to a front collision so i cant be them.
Old Dec 23, 2005 | 08:28 PM
stereo's Avatar
stereo
if you post the code I can look it up
Old Dec 23, 2005 | 11:47 PM
neonknight0311's Avatar
neonknight0311
I have the same problem with my SRS light. I noticed that when my fat ass ex wife sat on the seat one day the yellow light came on. She looked at the seat and the red light has been on ever since. Really, I think she crushed the sensor in the seat because after she sat on it and it went red, it went off and then it would only go yellow when weight was placed on the passenger seat. Now it is always red!
Same with the dealer, not sure what to do but the diagnosis would cost a lot of money. What to do? I think it is the connector beneath the seat, check there for binding or loose connections.
I'll keep an eye on this post.
Old Dec 24, 2005 | 07:22 AM
stereo's Avatar
stereo
on cars with the side airbags theres sensors built into the seat cushions ,the yellow light comes on when your in the path blocking safe deployment of the side airbag such as being to close to the door. you can read the code and reset the srs computer and see if it comes back on again
Old Dec 24, 2005 | 09:02 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
probably just needs the opds sensor replaced...most common code i see with side airbag accords...
Old May 15, 2007 | 07:31 PM
irobert82's Avatar
irobert82
Default Some help
hi, You know I have the same problem with my Civic, I was wondering if you found out how to turn the SRS light off, I would preciate your help, Thanks.
Robert
Originally Posted by zhizhi
I bought a car which is Honda Accord 1996. Unfortunately there was happened a car accident at the first day when I bought it to home. Then I found the SRS indicator light stays on after the engine started.
I don't know what's the problem with it. I heard of it will be very expensive to fix it. But I am just a student, I am afraid I cannot afford much money to repair a used car.
Please help me or give me a suggestion, if you can. Thank you very much!
irobert82's Avatar
irobert82
Default Some help
Robert
Originally Posted by amadiojr
I have a 96 Accord. SRS light came on one day while just driving, I was told it could be a number of things from the sensors in the seats, or in the seatbelts. It's possible it could be a fuse or the battery is to weak to power the airbag. I haven't attempted to fix it yet, so i can't better help you.
