Honda accord 99 front windows problem
first post so take it easy.
The front driver side window came off the track. i was wondering if anyone had any pictures(link?) so i know what i am getting myself into before i mess with it. this is my first time really trying to fix things myself. thanks
I never really worked on cars before either. And I totally replaced a broken window in my car(my old Plymouth though). It was a power window to, just take the door panel off so you can see the tracks and such. It wasn't to hard, but old cars are always easy, especially american ones. Honda seem to be more complicated everywhere, and i've never attempted to take the door panel off my Accord.
I can post images when I get home from work. But from the top of my head ...
How to remove the door panel
1 screw behind the door "sail". It's the black trim that resides from the opposite side of the rearview mirror.
1 screw in the door handle. You'll see a small plastic overlay, pop it off and see the screw.
2 screws under the panel. I'm trying to remember, and there should be a few screws on the on the underside of the door.
From there, the rest is all about popping seals. Start at the bottom of the door and gently tug towards you. You'll hear the pannel release from the frame. Finish the bottom then, gently tug upwards.
When you have the panel completely free, make sure to unplug the window harness.
You should have access to the glass, but (again, this is coming off the top of my head) there is a giant piece of plastic to keep moisture from window sills away from the panel. You'll have to remove the plastic by warming up the glued edges with a hair dryer.
