Belt Tension
Old Aug 31, 2002 | 03:01 PM
Baget's Avatar
Baget
All Show and No Go!
Default Belt Tension
Ok here is a really stupid newbie question. how the hell do i get off my belts?! i got a new alternator and i've been trying for the past long time to get the friggin belt off of it so i can get my new one in there. excuse my stupidity but can someone explain it to me?
thanks
Old Sep 1, 2002 | 06:35 PM
REbornHONDAneer's Avatar
REbornHONDAneer
Honda Biased
ok..get a wrench set and just start loosening every bolt you see. Hopefully the belts will fall off before the engine falls to the ground.
Do you have a manual of any sort? If youd ont you dont belong working on your car. Plain and simple. Hopefully you have one!
Dave
Old Sep 1, 2002 | 06:41 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
there are tensioners on each accessory... you have to loosen the bolts on what you are going to remove, with that done, the alternator will "slide" and the belt will loosen...
you dont need a manual to change an alternator... just reverse the removal procedure to get it back on. To tighten the belt, you may want to use a pry bar... and push on the alternator while you tighten the tensioner bolt.
Old Sep 2, 2002 | 09:29 PM
jtaccordvtec's Avatar
jtaccordvtec
use a bar and push on the supporting rotator forward. it will cause the belt to loosen up
Old May 28, 2004 | 04:33 PM
sharkwing1's Avatar
sharkwing1
what about putting the belt back on? what is the best order to put the belt on... what pulley first and what pulley last? thanks
Speedy400
8
Oct 8, 2004 11:47 PM
civicfan8
92+ Civic/EL & Del Sol
2
Sep 7, 2004 02:10 PM
Airboy
Oct 2, 2003 06:59 PM
petrv
Prelude
8
Jun 22, 2003 07:54 AM
excitid
CRX & Pre 92 Civic
2
Jun 30, 2002 08:24 PM
