Need help to take off my rim
Old May 22, 2005 | 10:42 AM
ilove2's Avatar
ilove2
Default Need help to take off my rim
I want to change my front and back brake yesterday, but I can't take my wheel off the rotor !!! they just stick up there and I try everything I can do to take the tire off, I try to make the tire flat then drive and little distance, but the tire came out the rim instead the rim came off the rotor, Can anybody help me with this problem
Old May 22, 2005 | 11:15 AM
wedley2's Avatar
wedley2
bboy Wesley West
so you want to take the wheel off?
have you tried loosening the lug nuts? lol...
when all the lug nuts are loose, give the tire a good kick while sitting down.
Old May 22, 2005 | 12:26 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
I really hope you're joking. If not, I think you need to take your car to a mechanic. You're going to end up doing far more damage to your car than the money you'll save from doing this yourself.
Old May 22, 2005 | 12:55 PM
oei28's Avatar
oei28
I think he/she already damaged the tires, driving off with completely flat tires for any distance can't be good lol.
Not sure exactly what you were trying to accomplish by making your tires flat, but if you can't figure out how to properly remove a wheel, I really don't think you should be changing your brake pads (at least that's what I hope you meant when you said you wanted to change your brakes) yourself.
Old May 22, 2005 | 01:18 PM
scanrps's Avatar
scanrps
Honda Parts Tech
I think we're getting played.
Old May 22, 2005 | 01:44 PM
98CoupeV6's Avatar
98CoupeV6
I would hope so.
Old May 22, 2005 | 04:42 PM
ilove2's Avatar
ilove2
I AM NOT PLAYING !!!
I know how to take off my tire and change the damn brake, I just change my front brake and back last time but this time those guys probly love that place and don't want to get out, it seens like the heat make it so sticky but I have no idea when they too sticky than normal
Old May 22, 2005 | 05:51 PM
98CoupeV6's Avatar
98CoupeV6
I hope english is your second language. If you're serious, take the lugs off and hit it with a large mallet and kick it...obviously not in the center(but I feel like I have to say it)...and it should come off.
Old May 22, 2005 | 08:26 PM
jschmid's Avatar
jschmid
I had the same problem with my neighbor's wheel...here in the rust belt those things can stick like mad. When mine do it, a moderate kick to the tire is all that's needed, but this guy's wheel was stuck for good. Turns out his son drove the car for a while on the rim without knowing it (brilliant, yes)...so after trying everything from sledge to torch, I finally just told him to drive it the 3-4 blocks on the flat real slow to the nearest tire place...the rim was already ruined.
But why you let the air out and drove on it blows my mind.
