headlight lamp manufacturers
Old May 17, 2005 | 10:06 PM
iduka's Avatar
iduka
Default headlight lamp manufacturers
I had the Sylvania Silverstars and they blew out in 3 months. Not cool. I live in San Francisco, so snow was not the problem, nor were my grubby hands.
I like how white they are, but am frustrated at how fragile/easily they blow out.
Can anyone suggest a different headlight bulb manufacturers with similar output of the Silverstar and if you've had good/bad results with them.
Old May 18, 2005 | 08:09 AM
magnanpi's Avatar
magnanpi
Silverstars look good,,,but didnt last for me either, only a couple months. I made a thread about it a couple months ago.
If you like the white look, for an somewhat inexpensive price, buy some PIAA extremes. Itll last you longer....
Old May 18, 2005 | 09:37 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
After experiencing the shitty quality of Silverstars, here's my policy: OEM or save up for HID.
Old May 18, 2005 | 10:36 AM
magnanpi's Avatar
magnanpi
^^^Or, even better, do what he said^^^
Old May 18, 2005 | 10:44 AM
newbb's Avatar
newbb
Default mine?
mine was some japanese product, it was expensive compare to other bulbs.
but it gives white since Feb. last yr and still going strong.
Old May 18, 2005 | 01:35 PM
illusion's Avatar
illusion
as was said, stop wasting your money on junk giimmick bulbs..
this is MUCH better in the long run(next two pics are cheap ass projector housings retrofitted with hella HID projectors)
Then not are are you not faking the color, you can actually see better
hell if you have a 6G, even just a cheap HID bulb retrofit works ok. I wouldn't recommend it on most cars, but the 6G accord responds pretty well to HID, not that bad of glare. I tried the bulb route in my wrx and was blinding the crap out of people, so I went with STi HID housings instead, but the accord wasn't bad, I'm just anal about lighting.(this is stock 6G accord headlamps, with rebased philips ultinon D2R, the faint blue line on the botton are the OEM fog lamps with riceboy blue bulbs in them trying to match the HID)
I spent more money on bulbs pre-hid than I did on my entire HID setup in the accord. I tried Silverstars, Nokya, PIAA(two different sets of $70 freaking bulbs), Polarg, you name, I tried it. All a waste of money, none with the true color, nor function of HID. Once I touched HID I have never even thought about buying the junk bulbs. I had my STi housings on my wrx within 2 months of buying the car. I've since added the leveling switch and harness which is a pretty cute feature
Old May 18, 2005 | 03:25 PM
Mr Hyde's Avatar
Mr Hyde
Accord Forum Moderator
Not everyone has the $$$ for an HID swap, but FYI, Silverstars are known for their short life. I had a set of Phillips bulbs back in the day which can be bought at any auto parts store which lasted me years. Not as HID looking as Silverstars, but not as fragile, or expensive either.
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old May 18, 2005 | 05:33 PM
illusion's Avatar
illusion
If they're continuously spending $50-$70 on a pair of bulbs that blow every few months or years versus HID which lasts for around 10 years, it's far more cost efficient to buy HID. Plus HID isn't just going for a pretty color, HID is brighter, a color spectrum that excites signs and road paint, in the end not only is it pretty, you can see further and better.
a wise man once said :You're not rich enough to buy cheap stuff.
I'm so addicted to HID I spent $3k more on a one year later benz even though the older one had 15k less miles, the 97 had HID.(97 S600, although I am regretting buying it, what a freaking money pit)
Old May 19, 2005 | 03:41 PM
skyshock21's Avatar
skyshock21
How much is an HID kit for a 6th gen accord?
Old May 19, 2005 | 04:09 PM
illusion's Avatar
illusion
$200-$300 for just a bulb retrofit, $250-$400 to do a projector retrofit(plus labor)
