CEL code help
Old Apr 2, 2005 | 11:25 AM
zell1985's Avatar
zell1985
Default CEL code help
My check engine light came on and i got the codes
i know from the forums that
P0304 - piston 4 misfire
P0303 - piston 3 misfire
but the third code i have not seen anywhere is
P01259
any help here please?
Thankds
zell1985
also if anybody could point me in the direction to find out what all the codes mean that would be helpful
Old Apr 2, 2005 | 04:24 PM
honda guy's Avatar
honda guy
I think its a Vtec code. Im gonna check into it for ya.
You didn't run the car low on oil did ya?
Old Apr 3, 2005 | 11:02 AM
honda guy's Avatar
honda guy
Yup P1259 is a vtec code. Its either due to low oil pressure or low oil or a bad vtec pressure switch
Old Apr 3, 2005 | 08:14 PM
zell1985's Avatar
zell1985
well it did run kinda low, not dangerously though, several months back but was immediatly taken care of, i had just had it serviced like a week before the light came on, and now it smells like something is burning....what can i do to check on these things, my mechanic said something bout a carbon buildup....but from what ive seen on the forums and this post that doesnt seem it at all so im not too sure i trust my mechanic now..
Old Apr 4, 2005 | 05:48 AM
honda guy's Avatar
honda guy
Carbon? That doesn't seem anywhere right. I would check the oil and make sure its full. If thats fine the only othere thing that can cause that code to come on is if the Vtec solenoid isn't operating when the PCM tells it to. So theres either a problem with the input to the solenoid or a bad solenoid. Either cases a scanner would be the only way i know of monitoring that.
Old Apr 4, 2005 | 09:38 AM
zell1985's Avatar
zell1985
well i guess im gunna have to go have a few choice words with my mechanic, ill check on the oil as soon as i go back to my car, thanks soo much for your help honda guy.
Zell
Old Aug 14, 2005 | 03:14 PM
RKV's Avatar
RKV
how much does it cost to change out a bad solenoid or a vtec pressure switch?
Old Aug 14, 2005 | 05:18 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
They're pretty easy to do yourself, at least on the J30A1.
Old Aug 15, 2005 | 11:38 AM
tdao1283's Avatar
tdao1283
yeah its real easy
Old Aug 15, 2005 | 12:59 PM
JimBlake's Avatar
JimBlake
Very easy on 4-cyl also.
The real trick is finding out whether the solenoid or switch is actually bad. The ECU can't tell the difference between a bad switch vs. a broken wire.
