another Dam problem (overdrive)
Old Mar 26, 2005 | 10:32 PM
hondadriver22's Avatar
hondadriver22
Default another Dam problem (overdrive)
this prob has been happening every now and then, like once a day or something during regular driving since i got another auto tranny put in. anyway this tranny has about 63,000 on it, and the thing is that when it goes into the overdrive gear it goes in pretty hard (it even shakes the car a little) this happens only when im driving like an old person. why is this happening???
Old Mar 27, 2005 | 09:04 AM
hondadriver22
is this another honda tranny sign of death?
Old Mar 28, 2005 | 12:46 PM
hondadriver22
well?
Old Mar 28, 2005 | 08:16 PM
hondadriver22
come on. someone has to know what this means
Old Mar 29, 2005 | 01:44 AM
bonestock's Avatar
bonestock
overdrive? do you mean downshift?
Old Mar 29, 2005 | 06:00 AM
blacknight07601's Avatar
blacknight07601
I think he's referring to when his car goes into the final drive gear. (highest gear possible/normally during highway traveling) My guess is that there is a problem with the tranny. But first check the trans fluid. Or even have it changed just to be sure. If that doesn't work take it to honda AND MAKE SURE you go on a test drive with them to point out the problem. A lot of times a service tech will take the car and bring it back saying nothing is wrong
Old Mar 30, 2005 | 09:11 PM
hondadriver22
thanks for the help, ill do a flush soon
Old Mar 31, 2005 | 08:23 PM
UCF Accord's Avatar
UCF Accord
Former Member
i heard you aren't supposed to flush honda trannys. just drain and refill, drive a little, and repeat until the fluid coming out looks like the fluid you put in. something about them being sensitive to the chemicals used in a power flush.
also, i don't believe honda's have an overdrive. they have a torque converter lock-up. if its locking up harder than normal, maybe your tc is dying.
Old Apr 1, 2005 | 12:24 AM
bonestock's Avatar
bonestock
its all hearsay. some say a flush can mess up the seals, some say a flush is needed to get all the metal shavings and debris that clog the clutch packets from getting proper ATF pressure...
Old Apr 1, 2005 | 05:01 PM
hondadriver22
i couldnt find any honda atf, but i got some dexron III (honda is specified on the back of bottle) stuff at autozone is this ok?
