problem with my brakes help!!
Old Aug 26, 2002 | 01:26 PM
DerekH's Avatar
DerekH
Default problem with my brakes help!!
1996 Accord EX AUTO, lately my brake pedal has felt mushy. Soetime when I am completely stoped the brake starts to travel down slowly and I have to press it all the way down so the car doesn't move. IF I pump it a few times it starts to work normally.
Old Aug 26, 2002 | 02:16 PM
Dr. Reef's Avatar
Dr. Reef
Perhaps you have gotten some air in your brake lines. I would suggest getting a new bottle of brake fluid, then bleeding your brakes. Consult the corresponding Haynes manual for your model car and follow the directions. It really takes two people to do it right.
Another alternative is that you have really worn the pads down on your car and are having to stomp even harder to depress what's left of them into stopping the disc/drum.
Old Aug 26, 2002 | 02:20 PM
dantastic's Avatar
dantastic
cx power!
either
a) air in the brake lines
b) low brake fluid
c) failed master cylinder
the master cylinder failed in my accord after 70kmi. but i drove that thing pretty hard :P
Old Aug 26, 2002 | 05:10 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
You could also have a small leak in one of the lines and pumping up the pedal is giving you more vacumm to help boost pedal feel.
Old Aug 27, 2002 | 07:22 AM
Is300man's Avatar
Is300man
just bleed the brake lines.
themonsteraria
92+ Civic/EL & Del Sol
3
Aug 21, 2009 03:36 PM
Black92Si
Mar 26, 2006 09:30 AM
asnlc76
4
Jul 15, 2005 03:12 PM
jlucas14
3
Aug 8, 2004 05:20 AM
NoRiCeHeRe
3
Jul 11, 2003 12:32 PM
