idle jumping PLEASE HELP
Old Mar 15, 2005 | 02:30 PM
VPUPPY's Avatar
VPUPPY
i would say check the fast idle thermo valve again, and make sure everything that needs to be connected to it is. the fast idle thermo valve uses coolant temperature to regulate the idle on your car, so make sure the coolant lines are connected and that your cooling system is full and air free.
Old Mar 17, 2005 | 10:53 AM
dgilling's Avatar
dgilling
Well my car has been at the honda shop for two full days now and they still cant figure it out. Does anybody know if it would hurt my car to bypass the IACV. Because when I do the car runs good it just doesn't have a cold start function. Would it cause any damage. Also if it is possible what is the best way?
Old Mar 19, 2005 | 11:37 AM
99Accolude's Avatar
99Accolude
heavy cars Rule!
how do you bypass the iacv?? please tell i have same problem with h22 99 accord.
Old Mar 20, 2005 | 01:07 AM
midnitekid19's Avatar
midnitekid19
Default vacuum hose might be the problem
My ride had the same thing going on. i have a 91 accord with a f20a engine. same thing, basically... anyways, it would rev high and low in park constantly until i drove off. the honda folks here checked it out and said that it was a vacuum hose that had collapsed. i'm not sure where it was, but if i remember right, it was in the back of the block. now my ride is working again... might wanna check it out. hope it helps... good luck.
Old Mar 21, 2005 | 04:43 PM
preludesitdrive's Avatar
preludesitdrive
i had this problem and it was because the coolant was low. try checking that out
Old Mar 22, 2005 | 02:37 PM
LowH22Accord's Avatar
LowH22Accord
Originally Posted by MarcD
The only other items the Helm manual show to check is the fuel injectors and the Map sensor. Is the engine light coming on?
yes the light comes on and when its on its running like crap but then it will cut off and it will run great, V tec will kix in and everything...ahhhhh it kills me
Old Mar 23, 2005 | 11:14 AM
MarcD's Avatar
MarcD
Have you tried to extract the codes yet on the computer?
