If anybody has specific technical or TSB questions...
Do you guys even read anything in threads before you post? He clearly stated that he doesn't have access to TSB's till January, and doesn't do diagnosis on this thread.
You guys have pissed him off so much he just won't respond anymore.
Do a little research and search threads yourself, don't make someone else do your work for you.
Hey man, I need an exploded view of the brake pedal light switch from a 99 LX coupe. After searching on here, I have identified the problem now it's time to change it. Also, do you know if this is straight forward or are there gonna be some surprises.
Hello,
It would be great it you could post this TSB. It covers the EGR problems on Odysseys from 1999 to 2001, although from what I understand only certain VINs for the 2001, which is what I am interested in. Thanks.
TSB info for my 1996 Honda Accord EX Sedan L4-2.2L SOHC VTEC.
SN050506 MAY 05 Wind Noise - Simple Way To Replicate
SN050600-011 JUN 05 A/C - Heater Blows Cold Air, A/C Blows Warm Air
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
98-058 AUG 98 Radio - Poor Reception/Static on AM Band
97-008 FEB 97 Radio - Static When Adjusting the Volume
Thank you
Thank you
