If anybody has specific technical or TSB questions...
Old Sep 22, 2005 | 07:09 AM
  #191
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by 03accord
Thanks for the TSB info!
RE: "7th geners" -- I always wondered how many Accords preceded mine -- now I know.
My local dealer finally got a chance to see the car yesterday. What I thought was originally an oil leak, and later a power steering fluid leak, turned out to be a leaking power steering rack. Part on order -- fortunately still under warranty.
Good deal, glad you got it fixed Post if you need anything else.
Old Sep 24, 2005 | 12:37 PM
  #192
Addicted2VTEC's Avatar
Addicted2VTEC
Do you have any TSB's for the 2002 Accord EX V6 Coupe Transmission. I am looking for one like Service Bulletin 98-061 , because my tranny is starting to slip and I don't have the money to fix it. I was hoping Honda had extended the powertrain warranty for 02's as well. Thanks for any help, it is greatly appreciated.
Old Sep 24, 2005 | 12:44 PM
  #193
98CoupeV6's Avatar
98CoupeV6
Well they didn't. There are countless threads on the auto tranny, you know that, do a search. Most people don't have a problem getting them replaced for free if you have under 100k miles.
Old Sep 25, 2005 | 08:51 AM
  #194
maguayoko's Avatar
maguayoko
Default 98 Accord Rear Springs - where/how rear bulkhead cover
Searched all over the trunk for the bolts to access the rear shocks/springs. I THINK the 'rear bulkhead cover' the directions talk about are outboard under the rear lap belts, but I don't know how to remove this piece. b4 I spend ALOT of time and effort I'd appreciate any information here thanks!
Kelly
Old Sep 26, 2005 | 08:10 PM
  #195
duh81's Avatar
duh81
Hi. Prelude owner here! Could you get me the TSB info for a 2000 Prelude, TSB# 01-010, Jan' 01? It's the flapping noise between 1800 and 2600 RPM. Much appreciated!
Old Sep 27, 2005 | 05:06 AM
  #196
embedit's Avatar
embedit
I've been getting a CEL that resets itself after several trip cycles since I bought my 2002 Accord LX (new). Dealer early on said it probably was tank seal detect. A friend of mine had a OBD reader when it happened yesterday, so I finally got to read the code (1164 H02S Circuit/Range Performance).
ALLDATA lists the following TSB for this vehicle:
00-046 AUG 03 Engine Controls - MIL ON/DTC P1164 Stored
I'd really appreciate it if you could get this one for me.
Thanks.....
Old Sep 27, 2005 | 12:04 PM
  #197
98CoupeV6's Avatar
98CoupeV6
Sure.
01-010
January 16, 2001
Applies To.: 1998-00 Prelude - ALL
Flapping Noise from the Engine
PROBLEM
The timing belt makes a flapping noise because it's improperly tensioned. The noise is most noticeable between 1,800 and 2,600 rpm.
CORRECTIVE ACTION
Replace the timing belt and the auto-tensioner.
PARTS INFORMATION
Timing Belt Kit (Includes timing belt and auto-tensioner)
P/N 06144-P13-305, H/C 8695878
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Operation Number: 110170
Flat Rate Time: 2.5 hours
Failed Part: P/N 14520-P13-003
H/C 4112686
Defect Code: 042
Contention Code: B07
Template ID: 01-010A
Skill Level: Repair Technician
Out of warranty:
Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
DIAGNOSIS
While holding the engine between 1,800 and 2,600 rpm, listen for a flapping noise near the timing belt cover.
^ If you hear the noise, go to REPAIR PROCEDURE.
^ If the noise comes from another area of the engine, disregard this service bulletin, and follow normal troubleshooting procedures.
REPAIR PROCEDURE
1. Replace the timing belt and the auto-tensioner (see pages 6-14 thru 6-18 of the 1997-99 Prelude Service Manual).
2. Verify that the noise is gone.
Old Sep 27, 2005 | 12:07 PM
  #198
98CoupeV6's Avatar
98CoupeV6
Thanks.....
Apparently you have not looked through the DTC thread, there is a procedure for how to find the code in there. This TSB will probably solve your problem, it sounds like your issue.
This is for the 98-02 Accord DTC P1164.
File Type: pdf
Old Sep 28, 2005 | 07:07 AM
  #199
eurodima's Avatar
eurodima
Life is short, Enjoy!!!
Default Need schematics
Hey 98CoupeV6.
Can you get the schematics for the factory alarm system for a 1997 Nissan Maxima?? I want to see which wires can be used to hook up the siren and which wires go to the blinking lights when locking and unlocking. Can you do that??? If you can, you can just e-mail it to me so it wouldn' take up space here in the forum. I will really appreciate it!!!!
Old Sep 29, 2005 | 06:47 AM
  #200
98CoupeV6's Avatar
98CoupeV6
Originally Posted by eurodima
Hey 98CoupeV6.
All sent.
Tomorrow is the last day I will be able to do this until January so you guys better ask your questions quick
