Does your car consume any OIL?
Old Feb 18, 2005 | 01:44 PM
Accord2.4's Avatar
Accord2.4
Default Does your car consume any OIL? (2.4L)
I have about 750 miles on a 2005 2.4L Accord. The oil level is about 3/4 full, but not quite at the full mark. Not sure if it came that way or if I'm using a bit of oil during break-in. Just curious if anyone else noticed oil consumption in the first few thousand miles?
Old Feb 18, 2005 | 01:54 PM
Gaaccord's Avatar
Gaaccord
Initial break in there is some oil consumption as the rings seat themselves. Technically less than 1Q every 1000 miles is not considered "excessive" by automotive standards.
I would top it off and see if anything else decreases... go ahead and buy real honda oil this time so you arent mixing types of oil.
B
Old Feb 18, 2005 | 02:44 PM
Accord2.4's Avatar
Accord2.4
Thanks. I know my last car said their might be a bit of oil consumption the first few 1k miles. I wasn't sure if the 2.4L was the same way.
Old Feb 20, 2005 | 02:26 PM
Accord2.4's Avatar
Accord2.4
Anyone else loose a bit of oil the first few thousand miles?
Old Feb 20, 2005 | 06:18 PM
motoguy128's Avatar
motoguy128
Not a measureable amount or enouhg to warrant adding any. You actually can get slightly better mileage and power if the oil level is a little lower. Less windage in the oil pan from the crank moving through it.
Are you sure your checking the oil after the engine has cooled off for at least 30 minutes? Otherwise there will still be some oil in the top end of the engine that hasn't settled back into the oil pan... which would make it read low.
Old Dec 25, 2005 | 05:26 PM
Accord2.4's Avatar
Accord2.4
I now have about 22k on an 05 Accord with the 2.4. I drive hard and the car sees 80mph on a day to day basis for about 50 miles. I usually have to add 1/2qt every 5k miles or so.
Old Dec 26, 2005 | 06:28 PM
92accordEXwhite's Avatar
92accordEXwhite
1/2 qt every 5k..... when do you change ur oil?
Old Dec 26, 2005 | 07:07 PM
blacknight07601's Avatar
blacknight07601
Also, if your car is being driven at high RPM's where VTEC (or in your case, I-VTEC) engages, that can consume a little oil also. Remember, VTEC operates on oil pressure
